Automatic Humidity Control - Match outside humidty
Old 11-18-18, 04:39 PM
Hi all,
I need to come up with an invention to match the humidity of two spaces, separated by a pipe with a fan on one end.
My guess is I need two humidty sensors, some "brain" that reads the inputs from the sensors, and if one is greater than the other turns the fan one way, if the other is greater inverts polarity on the fan.
So, that's what I need to do, but no idea what kind of system or sensors would do that simple job. How could I do that??
Thanks so much all for reading!
Old 11-19-18, 05:31 AM
airman.1994's Avatar
Received 8 Votes on 8 Posts
you can't push air out of a room unless you have air coming back into that space. If two rooms are separated by a wall just add some registers.
Old 11-19-18, 05:39 AM
XSleeper's Avatar
Received 667 Votes on 617 Posts
2 pipes.... 2 fans.... each blowing in opposite directions to mix the air... running constantly.
HTML code is On
