Nest 3rd Gen to Honeywell HC26A1008 Humidifier
Old 11-19-18, 10:21 PM
N
Question Nest 3rd Gen to Honeywell HC26A1008 Humidifier
I currently have a 1st Gen nest but purchased a 3rd Gen. I have a Honeywell HC26A1008 Humidifer installed on furnace and its connected to a humidistat and pressure switch on the furnace. I am looking to convert this to be controlled by my new nest I purchased. I may have to run extra wire to the thermostat which is fine. I have attached some pics of my current setup. Some guidance would help if anyone can provide some. Can I just wire it directly to Nest without having to wire anything to furnace. I assume I will no longer need pressure switch or humidistat obviously. Here are my images of current setup. Index of /NestHumid
Thanks Nick
Old 11-19-18, 10:52 PM
Received 1,110 Votes on 1,030 Posts
Welcome to the forums.
That's not the model number. That's the replacement media part number.
Maybe that's an HE-260 or 260A ?
What is connected to the furnace board...... just an R and C connection ?
Old 11-20-18, 06:38 AM
N
Oh my bad, Ya you are correct its a Honeywell HE360A. Looking at my circuit board on the furnace it has the R W Y G connection There is also a blue wire but thats not hooked up. So possibly could use that for the nest connection and humidifier somehow.
Old 11-20-18, 03:15 PM
N
Exclamation Update PIctures
I have installed the Nest 3rd Gen. I have updated my pictures attached so you can see current setup.
Old 11-20-18, 03:42 PM
You've used the blue wire as a C wire.
Do you have another extra wire at the nest for the humidifier control ?
Old 11-21-18, 06:03 AM
N
Ya I figured I would just run another wire if needed. Should be no big deal for me to get one there. So with the way its hooked up now I have the two yellow wires coming from the humidifier that go to the humidistat. Researching online looks like I may need a relay?
Old 11-21-18, 06:29 AM
N
Question Diagram with Relay Switch
I found this diagram in another post here. Does this look like what I need to do.
Old 11-21-18, 09:02 AM
Right now..... your humidifier has no connection to the furnace 24v control wiring.
You will need a 24vAC relay and the powered humidifier is the diagram you will need to follow.
Old 11-26-18, 09:32 PM
N
Nest is all setup and controlling humidifier. One thing people may want to know if they don't already is the nest does not do relative humidity. As it won't automatically control the humidity based on the temperature outside. Which would be nice for them to add so you don't have to worry about frosted windows. It knows the outside temp so not sure why it wouldn't be added or have this capability.
Old 11-27-18, 11:37 AM
It doesn't really know the actual outside temperature. It gets it online from a service.
It's a temperature based on the area average.
Old 12-03-18, 07:43 AM
N
Ya that's true but when it comes to setting the humidity it wouldn't need to be down to the degree accurate. Mine is always within a couple degrees. Just more control would be nice. For example if the temp is between 30-40 degrees have the humidity auto set to 35. Stuff like that.
HTML code is On
