Problems with Humidifier in recently purchased house
Old 12-02-18, 08:06 AM
I currently have a Honeywell HE260 Whole Home Humidifier installed just above my furnace. Whenever I turn it on, the furnace wonít do anything. Recently replaced furnace control board but everything else about the furnace is working perfectly. Not even sure where to begin. Any help is appreciated and I can provide any info or pictures if needed.
Old 12-02-18, 08:20 AM
Marq1's Avatar
Received 537 Votes on 497 Posts
As in the furnace will not turn on?
Every humidifier I have installed was hard wired, no switches, so appears to be a wiring issue!
Old 12-02-18, 08:45 AM
Thatís what I was thinking. Not sure where though. I have the red and white coming from my humidistat. The red is actually plugged into the HUM terminal in my control board. The white is tied off with the white going my solenoid valve on the humidifier. The red is connected to the R terminal on my control board as well. When I connect to the solenoid, my furnace wonít do anything, then gives me a pressure switch error code. If I disconnect it, starts right up.
Old 12-02-18, 04:06 PM
Received 1,616 Votes on 1,488 Posts
Whenever I turn it on, the furnace won’t do anything.
That humidifier will not turn on the furnace.
The furnace.... via the HUM terminals.... sends 24vAC out thru the humidistat to the humidifier when in heating mode. If you are connecting to a furnace board...... you connect to the HUM and C terminals..
Old 12-03-18, 10:56 AM
Thank you! I figured that out right before I came back to check with you. I know the humidifier wonít start the furnace, I think I just worded that wrong. I now have the necessary 24v going to my solenoid valve. I just have to fix my drain to my condensate removal pump and Iíll be good to go. As always, thank you so so much!
