Generalaire 1042 Humidifier to nest
Old 12-24-18, 07:53 AM
Z
Hello,
I have a question regarding connecting this humidifier to nest.
I previously Had a honeywell interface module that was incompatible with my new NEST gen 3. I have since ran new wires directly from the furnace to my NEST, but am not sure how to proceed with the Generalaire 1042 Humidifier (BYPASS TYPE).
I am Unable to upload a photo for some reason so I will write out my current wiring.
Humidifier has 2 wires, one white and one black
Humidifier (Black WIre) -> Honeywell Interface module HUM 2 spot
Humidifier White Wire -> Furnace Control board HUM.
The white wire is then replaced with a separate COM24 wire from the Furnace board and attaches to the HUM 1 spot on the interface module
From the interface module there were only 3 wires going to my thermostat (1,2,3). I have rewired upstairs to have W, W2 , C, G, Y, R plus 2 extra wires I can use for the humidifier if necessary.
Should I run the Bypass humidifier like NEST recommends (URL attachment below)? Or is there another way?
https://www.doityourself.com/forum/a...humidifier.jpg
Any help would be appreciated!
Old 12-24-18, 10:12 AM
Z
I just want to add that the interface module is not completely disconnected and not in use. All wiring goes directly from the furnace's control board to the nest
Old 12-24-18, 12:27 PM
A
Received 44 Votes on 39 Posts
The easiest way is to follow the diagram. Disconnect the EIM module and its wires completely. Then take one of the humidifier's wires and connect to the furnace COM terminal. (Black or white, doesn't matter which one) Route the other wire to the Nest * terminal.
Old 12-24-18, 12:39 PM
Received 1,109 Votes on 1,029 Posts
Weolcome to the forums.
The picture attachment system is currently under repair.
Agreed..... .the EIM module needs to be removed the system.
The humidifier is connected as shown in my diagram that you linked to.
Old 12-24-18, 09:28 PM
Z
Thanks everyone,
just rewired it and it works perfectly!
Old 12-24-18, 10:35 PM
Good job. Thanks for letting us know how you made out.
HTML code is On
