Aprilaire 600 Wiring to Carrier 59TN6A
Old 04-25-19, 03:17 PM
I’m having issues getting my Aprilaire 600 to connect and run through my Infinity Touch Control Thermostat SYSTXCCITW01-A unit. The unit has functionality to run my humidifier directly from the thermostat control. I’ve wired as per attached but my humidifier is not showing up on the display nor running at all....what am I missing? Should it not be plug and play? I did connect the OAT sensor that comes with the humidifier and the thermostat picked it up instantly...
Old 04-25-19, 04:59 PM
Welcome to the forums.
You posted the thermostat model number but what is the model number off the EIM.
It's the module shown on that page you posted that I can't read.
Old 04-25-19, 05:28 PM
Apologies, I didnít realize how poor the photo came out.
Last edited by PJmax; 04-25-19 at 06:01 PM. Reason: posted direct copy/labeled/sized/picture
Old 04-25-19, 05:30 PM
Still unreadable. What is the publication you are reading. There should be a number for it.
Old 04-25-19, 05:34 PM
It’s the manual for carrier 59TN6A as per my title.
Old 04-25-19, 05:51 PM
I figured it out, I needed to go into the setup menus and install the humidifier by holding the setup button for 10 seconds!!
Old 04-25-19, 06:02 PM
Ok. I also posted a diagram in your post #4.
Smilies are Off
HTML code is On
