wiring in new HSP 2000 steam humidifier
Old 11-06-19, 03:46 PM
E
In stalled a white Rodgers (Skuttle) 120v steam humidifier on a Lennox furnace running off a Generalaire GFX3 humidistat when the humidistat calls for humidity, water is boiled and the furnace comes on, but the AC also comes on ( compressor running) I know some humidistat can turn on the AC to reduce humidity, but I have nothing wired to the AC only wired to the fan thru an SPDT relay to allow the fan to run even if no call for heat
Old 11-06-19, 06:30 PM
Received 1,114 Votes on 1,034 Posts
Welcome to the forums.
You're going to have to post pictures or draw me a diagram...... How-to-insert-pictures.
Otherwise I'll be forced to guess at your wiring which will be of no help.
In some installations...... when there is a shortage of wires between the equipment and the thermostat...... they convert the Y (A/C) wire to a combo Y & G lines which means when you power the blower..... the A/C comes on.
Old 11-07-19, 07:38 AM
E
HSP 2000 wiring diagram
Link to humidifier diagram..... HSP 2000 (pdf)
Old 11-07-19, 07:38 PM
You misunderstood me. I know how to wire the unit. How did YOU wire it ?
I can't see your wiring.
HTML code is On
