How to connect a GeneralAire model 1042 to a Nest Learning thermostat
Old 03-25-20, 02:15 PM
V
Hi. Iím in quarantine for 14 days returning from Florida. I installed my Nest thermostat before Christmas without connecting my whole-home humidifier and air exchanger to it. Everything else work Fine. However, humidity in the house is now 20% and I need to connect my humidifier to my Nest but cannot have a technician come in the house for weeks and perhaps months. I have two wires (white and black) at the thermostat and same at the furnace of course which I identified in the attached pictures.
How do I connect it?
Old 03-25-20, 03:46 PM
Received 1,485 Votes on 1,373 Posts
Welcome to the forums.
Assuming your humidifier has the two wires from the solenoid on the outside of the unit.....
One wire connects to C on the furnace connection board.
The other wire connects to the * terminal at the nest.
Configure the nest for humidifier operation.
Old 03-25-20, 05:00 PM
V
Thanks. Just a few questions for an illiterate HVAC person...
How can I tell if the two wires from the solenoid are outside of the unit?
As you can see on the pictures, I have black and white wires terminating at the furnace and Nest thermostat.. Do I understand I only use one of them connected to the C connection at the HUM and the other end of the same wire connected at the * connection at the Nest thermostat? Does it matter if it is the white or black wire? What do I do with the other wire if no longer used?
Old 03-25-20, 05:03 PM
Just look at the humidifier. I believe with that series the solenoid is visible. It should have two wires on it.
In your two conductor cable you can use black or white. Just leave the other wire unconnected.
Old 03-30-20, 09:49 AM
V
Connecting Air Exchanger to NEST
Done, tested and now works fine. Thank you for your advice.
On another related subject. How can I connect my Greentek Air Exchanger to the Nest Learning 3rd generation. See attached pictures.
Old 03-30-20, 10:00 AM
Your nest can only run one external device via the * connection.
Old 03-30-20, 10:28 AM
V
Thanks. I will re-install the Air Exchanger thermostat beside the Nest or in the furnace room.
