Honeywell HM700 Electrode Humidifier from Trusteam
Old 07-23-20, 04:28 PM
G
I need help with my wiring on my newly installed Honeywell HM700 from my Old Trusteem. The problem is that the letters from my old unit are different in the new unit. Please see the pictures. The old is the color photo and the new (HM700) is the diagram.
As you can see the HUM, HUM, and Gf will match, But the R and The GT do not. I assume that the R can go RF but my green wire (which is my fan/blower wire) doesn't have a place to match. I know that I must keep my blue (GF) wire attached to the green (GR) if I want the fan to turn on when not heating or cooling. Should I just put both wires blue and green in the GF spot on the new unit?
FYI: My thermostat is integrated with humidifier control.
Any suggestions to help me wire this correctly will be appreciated. THANK YOU!
Last edited by XSleeper; 07-23-20 at 09:09 PM. Reason: resized pics and removed extra links
Old 07-23-20, 08:20 PM
Received 938 Votes on 875 Posts
Welcome to the forums.
Connect green and blue to Gf.
Connect yellow to Rf.
Gary Papazian voted this post useful.
Old 07-24-20, 09:10 AM
G
That worked! Thank you for your assistance.
Old 07-24-20, 09:04 PM
Good job. Thanks for letting us know how you made out.
Old 08-09-20, 09:55 PM
F
Received 10 Votes on 10 Posts
You might want to check inside your duct for moisture accumulation twice a winter. Shouldn't be a problem if the Installation Instructions were followed to the letter as to distances from upstream and downstream obstructions, but you never know.
Smilies are Off
HTML code is On
