Aprilaire Humidistat 62: Is there an offset function
Old 10-17-20, 01:35 PM
Installed an 800 steam unit. The humidistat is reading 6% too high. I tested it with 2 brand new hygrometers. The new hygrometers are reading exactly the same in various rooms, so I have a high degree of certainty that they are correct or close to correct. I don't see an offset function in the model 62 manual or any online references, OR, anyway to adjust the humidistat. I don't see any adjustment pods on the board.
thanks in advance for your thoughts.
Old 10-17-20, 03:18 PM
Received 1,110 Votes on 1,030 Posts
Welcome to the forums.
I don't know of any offset adjustment.
If you know that the sensor is xx amount off..... just add or subtract that from set point.
Old 10-17-20, 03:59 PM
G
Received 11 Votes on 11 Posts
Cheapo humidistats are notoriously off. Your 6% is better than most. I recommend living with it, and make slight mental adjustments to your settings.
HTML code is On
