Aprilaire 600A from A58 humidstat to old 60 humidistat.
I have a similar issue with my Aprilaire 600, and have tried the above wiring, but still cannot get the solenoid going. Here is how it' wired up:
R an C are connected to a 24v transformer on the side of the furnace, which is connected to the power supply 'before' the furnace control.
W is connected to W on the furnace.
I have the R on the humidistat connected to the Solenoid as well.
A jumper from the C to the 'left H on the humidistat, and the 'right' H connected to the other solenoid wire.
There is also a 'Com 24v' terminal on the furnace board. That red wire was previously connected to the 'Cf' on the old 58 Humidistat. now not connected to anything.
W was previously connected to the 'W/G' on the 58.
I separated this as your humidistat is not like the A60 as shown in the thread you posted in.
You have an Aprilaire 60 old style.... no A & B terminals.
The wiring between the transformer, R and C and the HUM terminals is not polarity sensitive.
The cable/wiring that goes from W and C on the humidistat to W and C on the furnace board must be followed.
MODEL: TUD100R9V3k4
experiencing issues with hooking up the manual stat to the furnace. After connecting the 5amp fuse popped does anyone know the appropriate way to connect? I am being told by the installer I will need to buy the automatic stat seperately in order to install and he reduced the blower speed to the lowest setting to accomodate the amps. Thanks.
[img]https://cimg5.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/image_50425601_8c9f04ad66b721075aee11cc74f93e457de40e9b.jpg[/img]
[img]https://cimg8.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/image_67156737_36e788943fab7f521eb267091765ab94bbf1eef8.jpg[/img]
[img]https://cimg9.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/image_50428161_6a5d0dac155c41a3e821fe1deb7d567eb0862c4d.jpg[/img]
[img]https://cimg9.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/image_50439169_34e07518264d69542fc24e3d2d1fa4be8318fb2d.jpg[/img]
Need some help wiring 700M to goodman GMSS92. I was going to wire it like so
AprilAire Relay 50 - white wire from blower to relay metal bracket, one line from relay to C on the board, the other line to humidifier solenoid
Humidistat - one lead to front facing pressure switch , one lead to solenoid on humidifier
The front facing switch connection is circled on the image, is that correct place to wire humidistat?
[img]https://cimg6.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1093/pxl_20221126_030921389_3_3fc6a0f3ab86c9c5f376e1a837877cefae9d12f4.jpg[/img]
