Aprilaire Model 560 Valve/Selenoid stuck open
Old 03-10-23, 02:44 PM
D
Received 1 Upvote on 1 Post
As I walked into the utility room toady, I noticed that the water was flowing in the humidifier while the furnace was off. I switched off main power to furnace, water still going. Same with humididstat set to off.
I did a couple of cycles closing/opening the supply valve. After about 5 cycles I got the solenoid to stay closed.
My assumption is that some dirt got inside?
Should I replace the valve?
Old 03-10-23, 03:11 PM
B
Received 235 Upvotes on 208 Posts
Dirt can get inside new valve. Better off investing in an in line water filter.
Old 03-10-23, 03:18 PM
D
The valve got stuck open again after the furnace cycled. I guess I need to replace it and add a filter?
Old 03-11-23, 04:33 PM
Received 3,415 Upvotes on 3,063 Posts
They can be taken apart and cleaned.
I've never installed a filter on one before but if you know you have a high mineral or sediment problem...... it couldn't hurt.
I do know first hand that if you don't have enough pressure going to it..... it won't shut off.
This is a typical problem with saddle type water valves that clamp onto the supply line.
Old 03-13-23, 03:05 PM
D
thanks. I turned the valve all the way out for a test. Still had the issue. Ended up replacing the valve. All is well again.
