Honeywell He360a1075 humidifier, ecobee wiring help
Old 05-22-23, 06:07 PM
L
I have a Honeywell humidifier He360a1075,powered,,,there's two yellow wires that go to the humidistat and pressure switch,,there're 2 red wires not been use on humidifier,,can i connect the 2 yellow wires from humidifier to acc+ and acc- without the need of relay.and if yes, the pressure switch and old humidistat will no longer will be use on the circuit,, right?
Old 05-22-23, 06:23 PM
Received 3,485 Upvotes on 3,128 Posts
Welcome to the forums.
The He360 is a powered unit (120v) because it has an internal fan.
There should be two wires coming out of the unit.
Connecting them together should make the unit run.
If that is what happens.... then you can connect those two wires to ACC+ and ACC-
Be sure to set the thermostat to two wire before connecting those wires....
or at least before plugging the He360 into the 120v receptacle.
Old 05-22-23, 06:33 PM
L
Thank you
I appreciate your fast response,I'll be doing some wiring right now,,,I'll set ecobee first,,,then I'll power the humidifier according to good advice you have given others, i just wanted to make sure if i needed the relay or not,,,take care,,keep up the good work...
