Aprilaire 500 wiring to new heat pump & oil furnace.
Installed a Gree heat pump and am trying to hook up aprilaire 500m with model 60 humidifier control. Furnace is a tempstar amp105-ie2 oil furnace with oil being backup heat. Current thermo is a honeywell rth7600d. I cannot figure the wiring out. Can i just tie into reversing valve (b/0) instead of using W. W- should only work if I'm in emergency heat. Also customer (my wife) wants hot water to humidifier. Is this a must....? its a very long run.
The blower motor neutral wire runs thru the metal clip on the A-50.
When the blower runs.... it turns on and activates the humidifier.
If you didn't want to set the transformer... you could get solenoid power from R and C terminals.
Unfortunately you do not get the most effective humidity output from a heat pump system with cold water. Hot water is definitely more effective. A long hot water line is not helpful either. Humidifiers don't use a lot of water so by the time the hot water reached the humidifier it would be shutting off. It would require insulating the line if hot water is used.
Thanks for the input. A tech told me to wire it to G instead of white and keep the fan on auto and in the summer turn off the controller, will that work as well? I am trying that today. I am running the hot water line....and insulating. I hope that helps a little.
G can't be used in dual fuel setups.
The heat pump will activate the G terminal but the oil furnace will not.
G is typically a faster blower speed than required for a fossil furnace.
I have recently purchased a home with an Aprilaire 600 system and an aprilaire 60 humistat. I am not getting any water flow to the water pad.
At first, I thought it was the solenoid, I replaced it, checked for water pressure to it, and still no luck.
Both solenoid wires are connected to H H.
[img]https://cimg6.ibsrv.net/gimg/www.doityourselft.com-vbulletin/1324x1672/screenshot_2023_11_04_at_3_26_50_pm_970a1c46002834ab6b693531b6f037e03d667093.png[/img]
Any thoughts? Please see pics for writing.
Read More
I am in the process of wiring the 62 Digital Humidity Control and I want to activate the Blower on my furnace without Heat when the 62 calls for Humidification. the reason i have the Honeywell HZ432 Control Panel is to be able to operate dampers on 2 zones. I only plan to operate the humidifier on Zone 1 the house, because my Zone 2 is the Garage which I do not wish for humidification.
My question is where to route the G (Blower) wire from my 62 DHC to the Thermostat side of the control panel or to the equipment side? Read More
