electrical fence
electrical fence
Can someone tell me if mig welding wire can be used as electrical fence wire.Thanks for your help
It could if you use stainless steel welding wire.
Normal mild steel wire would rust and cause problems.
Most any wire will work but some are better than others. My fence wire is all the cheap galvanized wire but it gets pretty rusty after 15 yrs. It's all still carrying the current but it is brittle and needs to be replaced. They also sell aluminum wire.
