Wasps Inside Of Home
I've found three wasps within our home in the past few weeks. They were feeble & inactive so they were easy to pickup & dispose of.
Problem is; where there's a few, there's likely to be more. Does anyone have any ideas as to how they may be getting in? We have good sound screens on windows & doors. It's a multi-level home & they've only been seen on the lower level.
There is a fireplace adjacent to that area but it has a damper & metal/glass doors over the opening. There's also a room with a suspended ceiling (composition tiles on metal hangers). There's a space between that ceiling & the rough floor above it. It joins with two outside walls. I'm already trying to check for a nest in there.
Any help or ideas you can offer will be appreciated.
Best regards, Dick
Best regards, Dick
Wasps
In most cases, when you find wasps indoors you will encounter only one or two at a time. Wasps are often spotted indoors in the spring when queens are looking for nesting sites or in the fall when they are looking for hibernation sites.
Should you find a wasp nest, wait until dusk when wasps have returned to nest and are inactive. Spray with wasp/hornet spray and wait before removing nest. Knock nest into plastic bag and seal. Then, dispose of bag.
On a nice warm day, check around the outside of your home. Bees and wasps are always back and forth from the nest. If there is a nest around, you should see them, if you're patient. Inspect upper levels and ground level as well. If there is no activity, chances are they were a fluke, like twelvepole suggests, and will die on thier own in a day or so.
Jay
Jay
Thanks for the replies Twelvepole & Roach Posse, they're appreciated.
We've had wasps around the house here before - but never on the inside. I know what their nests look like & have disposed of them before.
I now have a hunch that the few we've seen so far may have over-wintered under or near some rotting exterior wood trim. This is on the wall just outside of the room where I found them. This will be replaced soon.
Best regards, Dick
Best regards, Dick
