where online to get big rodent blocks
where online can I get pro BIG blocks of mice poison in plastic..???
large ones... HD doesnt have squat...
How big do you want? I've seen 1 lb blocks, but really, they get moldy long before they are used up. Us pro's use nothing bigger than 1 oz and many are smaller-for mice you use lots of locations, but small amounts. The 1 lb are for sewers, underground utility lines, so you can hang them from a wire and lower into the space.
Todays rodenticides will kill with a single feeding, but it takes about 1-3 days after that feeding. Over the counter baits are very effective. Tractor Supply is a good source for rodenticide,
or check local feed mills, farm supply stores, etc.
Excellent product, have about 40 lbs on my truck now. We use it in residential, commercial, and agricultural settings.
Another block that I like a lot is Maki Blocks. Either Contrac or Maki would be excellent choices.
Keep it away from dogs, as they like to chew on things. Also, opossums, raccoons, etc will eat them, too.
