Are window air conditioners completely sealed in/outside?
I get all sorts of bugs, hornets, etc in my window unit and am wondering if they are really totally sealed so outside stuff can't get in? I remember older units had had a damper that could be opened to let some fresh air mix with the inside air but none of my current units have this.
I do find the occasional bug or bee inside but they could be coming in other places...
Received 38 Upvotes
Units I have seen are not "sealed" but just have a tar-covered cardboard or styrofoam divider.
If they have a removable chassis inside a sleeve they generally have soft foam "rubber" around the outside to more-or-less seal the two sides. This foam rubber is easily damaged when removing or replacing the chassis.
I can see light through mine but I use an unvented gas heater so I see it as a safety plus. They use to, and I guess still do, make winter covers to go on the outside. I've seen those home shows suggest they should be removed in the winter but that seems strange and foreign to someone who grew up in the south. (Crazy Yankees even dig a hole in the ground and build their house on top of it.
Received 38 Upvotes
I grew up in a home that had a basement although the two homes I have owned have only had a crawl space. I REALLY wish I had a basement as it would make so many things in my life easier.
Crazy Texans put all their plumbing in the ground and then pour a layer of concrete over it. Then to add insult to injury they put their water heaters in the attic.
Originally Posted by PAbugman
I think that the greatest chance for insect infiltration would be where the shell of the unit meets with the top, bottom and sides of window rather than through the unit itself.
