Centipede's everywhere !! Help !!
Old 10-14-16, 04:47 AM
I've never had this problem before. There are way to many Centipede's running around in my house. There very creepy, and man are they fast little things.
I'm guessing due to my wet basement, that the moisture makes for the perfect living situation for these things.
Anyone know if the bug spray's that can be purchased at my local Menards would work on these critters ??
The label states that it kills ants, spiders, beetles, and various other insects. Just doesn't state that it works on Centipede's.
What do you think ??
Ron
Old 10-14-16, 05:56 AM
Received 83 Votes on 78 Posts
First thing I would do is address this wet basement, no moisture no more Centipede's.
Last edited by Shadeladie; 10-14-16 at 09:37 AM. Reason: Blog link removed. Not allowed
Old 10-14-16, 06:01 AM
Also, household centipedes are carnivores and eat ants, etc. If you get rid of the food source the centipedes won't hang around.
Old 10-14-16, 06:58 AM
P
Received 37 Votes on 34 Posts
Residual insecticide sprays, meaning that when they dry a residual chemical barrier is left, work well on centipedes as they readily pick it up as they travel. It sounds as if the whole house should be treated and that would eliminate aerosols. I can’t address what you saw at Menards.
If you are comfortable doing this, I would purchase a concentrate insecticide that you will mix with water in a compressed air sprayer. I’m assuming the basement is unfinished due to the moisture. Mix it according to labeled instructions and apply it at top of foundation wall and joist junction as well as wall/floor junction. In the living areas I’d treat under appliances and carefully crack and crevice treat baseboard areas if possible, wiping up any pooling/runs. In sinks/bathrooms treat into the wall or floor where the pipes penetrate. Treat garage as basement. Treat exterior, especially where exterior wall meets soil, about a foot out and foot up. I’d treat soffit areas to as high as I could.
Bifenthrin is a good active ingredient available in various brands. I’ve seen it in big box stores as well as on-line.
Hope this helps. I’m going to be out of touch soon.
