Rats running up my vines
Old 12-12-18, 09:35 AM
I need to prevent small furry animals from climbing up my vines on my house. I have another on the other side of the house. How?
https://imgur.com/gallery/5GhQOgw
Old 12-12-18, 12:18 PM
Received 188 Votes on 175 Posts
How do you feel about sitting outside with a bb gun? Most reliable would be to cut down the vines. They are perfect for mice, squirrels and other critters to climb.
Old 12-12-18, 01:30 PM
Received 18 Votes on 17 Posts
Are they thick vines?
Were you thinking about something like the metal cones that are used to keep squirrels out of bird feeders?
Old 12-12-18, 02:05 PM
Received 23 Votes on 19 Posts
Two thousand volt anti-critter electric fence charge unit - $30
Two hundred and seventy-five feet of electric fence wire - $7
One motion control outlet. $13
Hours of entertainment - priceless
Old 12-12-18, 04:36 PM
Shadeladie's Avatar
Super Moderator
Received 39 Votes on 31 Posts
Surely there are more humane methods than bb guns and electrocution! There's something wrong with someone that would find that entertaining.
Old 12-13-18, 06:27 AM
Received 24 Votes on 20 Posts
I'd be setting up rat bait stations.
Old 12-13-18, 12:40 PM
I do not use poisons in an open, uncontrolled area. It's too easy for non-targeted pests like cats, dogs being poisoned.
Electric fencing is not effective against small rodents. It's too hard to position the wire close enough for them to touch the wire without the wire being shorted out on leaves and vines moving in the wind.
A wall covered in multiple strands of growing vine has too many paths for a critter to climb. You can't put anti-rodent cones on a vine when it's flat against a wall. And when there are multiple vines in close proximity it's easy for an animal to jump from one vine to another bypassing your obstacles.
Then there is the problem of your trellis attached to the house. Another perfect avenue for critters to access the house. Removal of the climbing paths is really the only option I see. Get rid of the trellis and vines. Other than that it is you out there personally trying to scare them away.
