cost of dow thermax finish board
Old 08-16-02, 11:59 AM
sclancy
i am trying to find the approx cost of Dow's thermax foam board that has a radiant barrier on one side and that has a white aluminized finish on the other.
any help here is appreciated. the product is going to be used in my wine cellar since it does not need to be covered with drywall.
thx
Sean
Old 08-18-02, 12:17 PM
rbisys
Greetings,
I'm guessing you need much structural strength either, because that it isn't.
A radiant barrier is an excellent choice for the wine cellar. Be sure to do the ceiling too.
An alternative would be double bubble foil radiant barrier material. It is available in foil one side and white plastic the other.
The heavy duty costs about $.35 /sf plus frieght. I forget the size of the rolls.
If you can't find it locally, I'll order for you.
