Can I or can't I?
mheadboy's Avatar
08-30-02, 08:51 AM   #1
mheadboy
Can I or can't I?
Is it ok to use fiberglass insulation against concrete walls in my basement? I'm in CO and the basement is very dry.
rbisys's Avatar
08-30-02, 04:29 PM   #2
rbisys
Greetings,
By all means if you don't mind condensation and mold.
You can install a 95% effient radiant barrier and eliminate the condensation and mold and have a warmer basement.
How do youy plan to furr out? If you do not plan to have electrical out lets on the out side walls you can use 1x2 and a single radiant barrier.
Thank you for considering my opinion.
mheadboy's Avatar
08-30-02, 08:49 PM   #3
mheadboy
I'm furring out with metal stud, and I do plan to have electrical in the wall. If I place plastic against the concrete will that act as a vapor barrier?
resercon's Avatar
NJ
08-30-02, 09:36 PM   #4
You can go to http://www.ornl.gov/roofs%2bwalls/facts/index.html and read "Builder Foundation Handbook" it is written by Oak Ridge National Laboratory. You can also go to http://www.eren.doe.gov/consumerinfo/refbriefs/bd4.html it is written for the U. S. Dept. of Energy on vapor barriers. The whole page is good, but you want to pay special attention to "Thermal-Moisture Dynamic." You can also go to my message board where I answered a simlar question some time ago at http://resercon.com/msgboard.mv?parm...msgnum=1000011 It discusses how moisture occurs with insulation installed in basements and how to avoid it. I do not wish to confuse you but there are basically 3 ways heat is transferred, conduction, convection and radiant. With insulation it is heat that carries the moisture. All 3 links discusses diffusion which is a mechanism used in conduction.
rbisys's Avatar
09-02-02, 01:14 PM   #5
rbisys
Greetings,
Installing pastic on the concrete will not prevent moisture getting to the fiberglass. Why even consider a product that is less than 10% efficient and subject to mold.
You can install a 4 mil radiant barrier against wall letting it drape to the floor and then installing your wall. This way you have 100% coverage, easy to install and no mold problems. PLUS you have a superior vapor barrier.
