insulating floor in mobile home
I am looking for tips on insulating under the floor of a mobile home that has a dirt crawl space.Type of insulation;should i add a vapor barrier and where?It is in northern pennsylvania.
You could glue rigid fiberglass insulation boards or styrofoam boards to the bottom. Liquid nails should do the trick for you. Just read the application instructions carefully before applying.
