Insulation for range hood vent pipe
Old 09-12-02, 07:32 AM
dons
The hood over my range vents to the outside via an 8 inch vent pipe that runs horizontally between the joists in the ceiling of the kitchen. Is it permissible to wrap this in insulation? If so, what kind of insulation do I use?
Old 09-12-02, 09:33 PM
L
Don't insulate it. First, there is no reason to. Second, and more importantly, whatever you used would probably be flammable, thereby creating a fire hazard. THAT is why you will never see one that is insulated, and why yours was never insulated when it was installed.
Old 09-13-02, 07:41 AM
dons
Thanks, lefty. I'll definitely leave it uninsulated.
I raised the question because I had read in another post about someone insulating their hood vent pipe when it went vertically through the attic. There was an issue of condensation. But I guess that's not an issue here where pipe runs horizontally between the ceiling joists.
