Insulation
Old 02-17-00, 10:49 AM
Red face
I moved into a newly contructed home in 10/99. An excessive amount of cold air is coming from the area of the base boards.
The home was suppossed to be well insulated and I believe it is except for this.What could be causing this and how can it be stopped?
Old 02-18-00, 01:01 PM
Post
cs -
I am going to move this topic to "Insulation" because it seems to be appropriate there...
Lydia
DoItYourself.com
Old 02-19-00, 04:34 AM
Post
CSsmith:
If you are feeling a draft around your baseboard, that means there is a hole or crack somewhere. Chances are it is at the bottom of the siding. It might not have gotten calked. Your house should still be under warrenety if it is a brand new built house. If not, I would try running a line of calk around the bottom of your siding.
Good Luck
Jack the Contractor
[This message has been edited by Jack the Contractor (edited February 19, 2000).]
