No Vapor Barrier in Old House
1st: House built in '55, there are no vapor barriers. 2nd: There are a couple room's where the ceiling is partially below the attic areas, how can I add insulation or replace (old bat's are barely 3" thick) and get it next to the ceiling and have a vapor barrier???
Thanks
Thanks
Hi:Falcon2dr
First off, an attic is not exposed to the outside like an exterior wall. The roof is exposed to the outside.
Therefore, if you have an attic, the insulation in between the rafters does not need a vapor barrier. Hence you can use blowen in insulation in place of bats.
If you need insulation in the walls that are outside walls, a vapor barrier will need to be installed.
There are several different types of wall insulation materials and various methods of installing each type. I suggest you check the archives in this forum for more information.
Good Luck.
Sincerely,
TomBartco
TomBartco Enterprises.
Trade:Natural Gas Energy Consultant & Technician.
Appliance Service & Repairs Rep.
Vocations:Saw & Tool Sharpening. Small Engine Repairs.
Accurate Power Equipment Company.
Personal Quote:
"Drive Safely. The Life You Save, May Be Your Own."
Good Luck.
Sincerely,
TomBartco
Personal Quote:
quote:<HR>Originally posted by TomBartco:
Hi:Falcon2dr
Good Luck.
Tom can you call collect 403 252 9632 I can seem to get my question through to you
<HR>
