Garage isulation
Old 05-01-00, 12:40 PM
Question
I've turned my garage into a woodshop. I do not plan on heating it but would like to insulate the roof so it stays a little warmer in the winter. It also needs a new roof. Instead of insulating inside can I use rigid foam over the current shething without causeing a moister problem and reroof over that.
Old 05-06-00, 03:26 PM
Post
This will work, but are you sure that you want to DIY? Do you have the time to sink into this project?
Depending on where you live I would recommend the rigid foam and a metal roof over it.
MTAC - Van Buren,MO
www.carpenter.cjb.net
Home repair & Construction
"Where the character and work are always upright"
Anything worth cutting down a tree for, is worth doing right.
www.toolreview.cjb.net
