to lefty
Old 07-07-00, 05:26 PM
Guest
Cool
I would like to have owens corning installed by a pro. r-30 in the ceiling,r-13 in the exterior walls,and r-19 in the crawl space.I live in Delaware if that helps any.
Old 07-07-00, 08:18 PM
Guest
Post
Jake, after rereading your initial post, I gather you are in the process of building this house, so you will be insulating as you go. One phone call to a Home depot, Lowes, Home Base,etc. will give the price of the insulation per sq.ft. If you will be installing it yourself, that price plus your time will be the cost. If you need or want to have it installed professionally, then you will have to add the labor cost of doing so. If you can take a set a plans to an insulation contractor, he or she should be able to give you a bid within a few days.
