07-08-00, 07:09 PM
I have heard pros and cons regarding insulating the floor with fiberglass insulation in a conventional foundation. Any suggestions? I also heard that instead of insulating the floor, I should spray insulation on the block wall instead. Anyone know?? We are building now so need an answer asap. Thanks!
07-12-00, 04:09 AM
You should check you insulation codes. Several years ago, the codes said to insulate all foundation walls, then they changed to insulate the floors. I always insulate between the floor joists with rolled insulation, paper on one side.
07-22-00, 11:10 AM
Why not use 2x3s or 2x4s as floor joists and use 1 7/8" or 2" rigid foam between? This will give you between 10 and 14 R on the basement floor.
