Insulation Choices
Old 10-16-00, 11:38 AM
Post
I just had a house built and the garage door they installed has no insulation in it. Can you reccomend an insulation that I can attach to the inside of the garage door to insulate it from brutal winter weather? I need something that will not affect the garage door opening and closing. Any suggestion you can give will be greatly appreciated. Thank you.
Old 10-17-00, 03:09 AM
Post
You could glue sheets of foam insulation to the inside of the door.
Old 10-19-00, 03:20 AM
Post
If you had a house built, you chose the type of garage door, wheather you knew it or not.
You should have gotten an insulated one.
