Insulate raised ranch
I have a raised ranch with a finished lower level. The upper wall is above ground and it is insulated. The lower wall is a concrete foundation, studed 2X4 with sheetrock. I would like to insulate this. Other then removing the sheetrock is there another way?
Thanks AL
Thanks AL
Contact an insulation contractor who has the equipment to blow cellulose insulation into the stud cavities. He will bore small holes in the wall at each cavity and fill them. You will need to plug the holes afterwards. Much simpler, quicker, and less messy than resheetrocking.
Previous Thread
Next Thread
