Polyfoam insulation
lmarilyn's Avatar
11-04-02, 04:03 PM   #1
lmarilyn
Polyfoam insulation
Are there problems involved in using liquid foam insulation in an older home? What if I need to repair plumbing or wiring?
resercon's Avatar
NJ
11-05-02, 04:50 PM   #2
I usually recommend upgrading the wiring if foam is used. Plumbing is usually not on outside walls, however, in older homes you will find some. Even so, you could not snake out the plumbing, you would have to tear open the wall. The foam comes out quite easily.
