basement floor joist insulation for sound control
Old 11-04-02, 07:53 PM
workatit
I am planning to install R-19 insulation between basement floor joists to provide sound insulation from the basement (teenage tv and stereo). I was going to use the paper faced fiberglass with the paper facing down to get a compression fit between joists. Some of the insulation will be above a drywall basement ceiling and some above a suspended basement ceiling. Are there any long term problems with doing this installation?
Thanks in advance for your advice.
Old 11-04-02, 11:05 PM
bungalow jeff
Get insulation support wires (they wedge between the joists to support the insulation) for the areas above the suspended ceiling.
Old 11-05-02, 05:19 AM
workatit
Bungalow Jeff,
Thank you for responding.
Does it technically matter whether I use the kraft faced or non-faced? Are there any long term benefits / problems using one or the other?
Old 11-05-02, 09:59 AM
bungalow jeff
I believe the benefit of the craft faced insulation ios the nailing strip. The paper does not constitute a vapor barrier.
