Insulating Pier and Beam house
My house is built on Pier and beam giving me an approx 30" high totally open crawl space under an uninsulated 1 1/4" subfloor and then a wood floor on top of that. Is batt insulation the best way to go? Maybe covered by foam board? Which way should the paper go - to the house or to the grade? Any help is appreciated!!
Robert Diaz
Robert Diaz
Batt insulation would likely be the simplest to install. The paper usually faces the living space, because it is a vapor barrier. There is a product for holding batts in place under a house. They are along the lines of a plastic or metal rod looking affair that one pushes into place between the joists to hold the insulation up in place. You can get a batt that is wrapped in a plastic material that is manufactured to pass vapor so that you could use them under the house rather than the raw batts, if you already have a vapor barrier installed.
