Radiant Barrier for Wine Cellar
Old 02-25-03, 02:27 PM
mroyer
Any info regarding the using of RB in a basement wine cellar?
Old 03-03-03, 03:48 PM
T
Insulating Wine Cellar
If a climate control cooling unit is going to be used, you will need to insulate. The R factor or thickness of insulation is determined by the thickness of the walls and ceiling. For example, fiberglass insulation of R13 is designed to be used in a 2x4 wall. R19 is used in a 2.6 wall. It is important to use the correct insulation for the wall thickness.
R13 is a recommended minimum for walls. R19-R30 for ceiling. Fiberglass or Rigid Foam is typically used. Insulation is important to keep temperature constant.
