Insulation rolls & supports not wide enough
Old 03-12-03, 09:47 AM
brewhill
I'm helping a friend put insulation in his spare bedroom ceiling and the standard insulation rolls and supports aren't wide enough. The house is over 100 years old and the joist spacing varies widely.
His thought was to put the insulation in perpendicular to the joists instead of parallel to them but this requires a lot of extra work.
Another thought was to install one row of insulation and then a overlap a second row to fill the space. Will this insulate properly?
Any other ideas?
Old 03-12-03, 06:33 PM
willywhy's Avatar
Do it his way
Get some stiff wire like coat hangers and jab them in to the joists.
Your way would be twice as costly and uneven, dont pack it in.
Get yourself a couple of 2by's and the job will go quick.
Old 03-12-03, 06:45 PM
rhhjr
is the attic above this bedroom ? if so, blow in cellulose insulation.
Old 03-13-03, 06:25 AM
brewhill
Unfortunately, there isn't an attic in this house.
Are coat hangers strong enough to hold the insulation?
