Foam coating
Larry1097's Avatar
03-27-03, 08:37 PM   #1
Larry1097
Foam coating
I am putting foam sheathing on my foundation. And I seen some buildings they have sprayed or trowel a coating on over the foam and I would like to know what type of coating this is.
Thank You
chfite's Avatar
SC
04-07-03, 04:14 PM   #2
I believe it is a stucco-like product called drivet.
YankeeCraftmn's Avatar
04-08-03, 05:34 PM   #3
YankeeCraftmn
Chfite is correct, its a stucco product name. You have to do this because the UV rays deteriorates styrofoam in no time. If you plan on leaving exposed areas use the blue board instead.
I need spell check, sorry.
