05-03-03, 06:07 PM
galump
Any one have any ideas on how to insulte the underside of an older home with hardwood floors that is built on piers. At present it is open underneath. the piers are 18 inches.
Thanks,
martin
Thanks,
martin
05-03-03, 06:10 PM
galump
How do you insulate under a home that it built on piers? It is open underneath. Has hardwood floors.
Web Hosts Note:
This question was found in multiple forums.
The question now has been merged into one within this forum to consolidate the locations.
Tom_B.
Web Host & Multiple Topics Moderator.
Web Hosts Note:
Tom_B.
CAL
05-03-03, 07:09 PM
Hello: Martin
Local building supplies stores have already cut to fit insulating materials, tools and proper protective attire required to do this do-it-yourself project.
The space beneath the house must remain open to ventilation air. Closing off any air from circulating under the raise foundation will cause mold and mild to form and cause wood rotting.
This question on insulating a raised wood flooring has already been asked in this forum. Reading like and similar questions pertaining to insulating will provide additional information.
Regards and Good Luck.
Web Site Admin, Moderator Hiring Agent, Host and Forums Manager. Energy Conservation Consultant & Natural Gas Appliance Diagnostics and Repair Technician. Fast, Fair, Friendly and Highly Proficient...
Don't Take Freedom For Granted. Thank A Veteran. Need an Employee? Hire a Veteran
Not only is a mind a terrible thing to waste, it's like a parachute.
It doesn't function until it's OPEN...
Elvis. "The Sun Never Sets On A Legend."
Gun safety is using BOTH hands!
Driving Safety Reminder:
Buckle Up & Drive Safely.
"The Life You Save, May Be Your Own."
NC
05-03-03, 09:39 PM
Use insulation batts with the vapor barrier side up towards the heated space.
Hold it in place with "tiger claws" made for the purpose (pointed stiff wires that reach between the floor joists).
Don't "crush" the insulation.
Wear long sleeves, gloves and eye protection. You will be in for a "dusting" of fiberglass particles. Take a cold shower (shrinks pores) afterwards to remove the fiberglass particles.
Good Luck!
Mike
Good Luck!
Mike
