insulation
Old 05-14-03, 07:07 AM
GORDON HAMMER
insulation
the insulation under my porch now is a white fibre board type, would you advise me to remove & relplace with the fibreglass insulation you spoke with me about?
Thank You
Gordon
Old 05-14-03, 08:08 AM
R
It depends on your situation. If the present insulation is adequate then I would leave it alone. If it is not but it is easier to add more of the same kind, then I would do that. If it is not and the fiber board is degrading and/or for some other reason you find it inadequate, then I would remove it and replace it with the fiberglass insulation. I do not approve of mixing different types of insulation in the same area.
