how to insulate from the exterior?
Old 08-17-03, 09:05 AM
B
Hey,
Thanks for the replies to my other submission I understand that the paper on the insulation should face the interior, but if i insulate from the exterior, how would i staple the bats in? Is it even possible
Thanks
Old 08-18-03, 09:15 AM
Ed Imeduc's Avatar
Insulation
Most of the time it will stay there when you push it in the studs with the paper to the inside wall. If not there is a wire that you can get that will fit between the studs and hold it there till you cover it up. You could use a glue gun here and there and then push it in. ED
