Basement: faced insulation PLUS plastic sheeting?
Old 11-12-03, 09:53 AM
bobbyo8
If I get faced insulation batting and staple the tabs to my 2x4 studs, do I need to add 6mil poly as a vapor barrier before I sheetrock too?
Should I put a bead of caulk along each stud before I staple the facing to make it really seal good?
I haven't bought the faced insulation yet, I just would like to know what would be best (and of course easiest to install and/or cheapest!)
Thanks in advance....
Old 11-12-03, 12:48 PM
Ed Imeduc's Avatar
V/B
We just put a 2mil poly over the paper and studs as one big sheet then dry wall. Dont caulk. ED
Old 11-17-03, 05:43 AM
awesomedell's Avatar
Bobby, the answer to your question is determined by where in the country you live. Ed is in Fla, a very humid place year round and that is why I'm sure that the poly is recommended over the paper faced insulation. Here in the midwest it more of a either or situation. If you're in a basement we typically use unfaced insulation with a poly barrier installed over the studs prior to sheetrocking. On above grade exterior walls faced insulation is used without a poly barrier. Check out the DOE's (Dept of Energy) website for correct regional recommendations.
Oh yeah, like Ed said, no caulk!
