faced insulation
Old 11-12-03, 03:42 PM
faced insulation
I have a walkout basement with block foundation. At the highest point the foundation is about 3.5' high. I have built 2x4 "half walls" and spaced approx 1" from foundation. I used faced R13.
Is it ok to use 2 pcs butted in the same cavity with a seam, and if so do I need to seal the seam? I have done that on a few cavities as I had a lot of cut pcs.
I thought about just putting up some poly over the facing, is that acceptable?
Thanks
Old 11-12-03, 08:16 PM
You could tape the seams with either duct tape or aluminum tape. This will work better than using the plastic.
Old 11-16-03, 11:12 AM
wd8cdh
dtro,
The Kraft facing on insulation is rather usless as a vapor barrier. The resistance to moisture of a poly sheet is about 50 times better. I would reccomend taping the seams of the poly with tyvec seam tape or other tape with long adhesive life. The gllue on duct tape will fail in about 5 years.
Ron
Brookhaven National Lab
Old 11-16-03, 01:10 PM
Ed Imeduc's Avatar
Lightbulb V/B
Just get the poly So it will cover the whole wall for you over the insulation then put up the drywallare what ever ED
Trackbacks are On
Pingbacks are On
Refbacks are On
