Attic Insulation
Old 11-14-03, 10:45 AM
cosvog
Question Attic Insulation
My wife and I would like to add insulation to our attic which currently has vermiculite insulation and no rafter insulation. The house was built in 1911 and the insultation was added over time.
1. What would be the best method of adding insulation?
2. Should we have a contractor remove the vermiculite insulation then add more modern insultation?
3. Everntually we would like to finish the attic and make it actually part of the house (thus providing a fantastic view of Mt Rainier)
Thanks
Old 11-14-03, 09:04 PM
C
Ordinarily, you would just add loose or batt insulation to reach the recommended R value. You can leave the old insulation in place. There is not much point in throwing it out then having to replace it. Besides, if the vermiculite has asbestos in it, it will cost a fortune to remove it.
Asbestos is always considered dangerous.
Asbestos: What you should know: Asbestos is a hazardous material that can cause serious disease when inhaled. Anytime it is disturbed, it becomes airborne. Then it can be inhaled. http://www.lungusa.org/air/air00_aesbestos.html#what
Asbestos: What you don't know can hurt you and others: the fibers are easily transported home on your clothes and in your vehicle after working with Asbestos. The fibers stay airborne for a long time. Asbestos does not go away, it stays around for many years. Asbestos is in thousands of products throughout the country. http://www.lungusa.org/air/air00_ae...html#protecting
Asbestos: The rules and regulations and laws require that clean up, removal, transport, packaging, and disposal be done under strict, specific controls by trained, insured professionals under stringent guidelines. http://www.epa.gov/ttn/atw/40cfr61.01.html
Asbestos: The only way to tell if Asbestos if present is by testing samples of suspected items.
http://www.atsdr.cdc.gov/asbestos/a...tectingasbestos
More information: http://www.pp.okstate.edu/ehs/links/asbestos.htm
Gaining some extra space in the attic can be quite attractive.
Hope this helps.
