Insulate A Basement Floor?
Old 01-28-04, 11:18 AM
wmehojah
Question Insulate A Basement Floor?
Is this possible? The basement is dry, and we sealed the walls and floor over a year ago, so moisture isn't a problem. The floor will be mostly carpeted, except for the laundry/utility areas. The floor is always ice-cold in the winter, can we put something on the concrete, and then padding and carpet on top?
Thanks in advance.
LA.
Old 01-31-04, 06:53 AM
luisduo
I have seen a product called "Dri-Core". It's a sub floor system for basements with wood on one side and a plastic bubble system on the other side.
http://www.dricore.com
Old 01-31-04, 09:12 AM
LAJams
Wow, that appears to be exactly what we need. Time for more research. Thank you!!
Regards,
LA.
Old 01-31-04, 09:27 AM
michaelshortt's Avatar
I saw it at Home Depot.
