insulation
insulation
I have insulation in 2 X 6 walls with the kraft paper facing the inside walls. The iside has no drywall yet. I had to remove some insulation to put a dryer vent through the wall and the outside wall was covered with frost pretty heavy. Is this normal and won't it cause problems when this melts?
Received 1 Upvote
1 Post
It sounds to me like the paper on the insulation was not put in there right and lets warm moist air into it . This is why we put up over any insulation with paper on it a 4 mil poly V/B over the ceiling and all out side walls then the dry wall ED
