adding insulation
Marsha's Avatar
02-05-04, 03:55 PM   #1
Marsha
adding insulation
When adding insulation in the attic, can you place batts over blown-in insulation?
Dave_D1945's Avatar
02-05-04, 04:07 PM   #2
Should be no problem if you use unfaced batts. Batt facing acts as a vapor barrier so you wouldn't want that between the blown in insulation and the batts - you would trap moisture.
