insulating an addition built on a deck
Old 08-12-04, 06:07 AM
sway22
We just bought our first home and the addition is built on top of the original deck. I would like to insulate the floor but noticed that 3 of the 4 sides are open (outside the crawlspace). What can I do for insulation and protection against the weather?
Old 08-12-04, 06:40 AM
deck
Greetings,
Need more info.
What part of the country are you in.
Are you sure there is a strong enough footing.
Can you seal the openings air tight.
Do you have GOOD drainage or can you install a sump pump.
This is not a simple matter of just pushing some insulation in there.
Old 08-13-04, 01:55 PM
Ed Imeduc's Avatar
Wink
You dont say what the joist are there . But lets go this way. I would put up a R19 up in the joist with the paper side too the floor room. Now you can close that in with a siding on the under side of the joist are you could put up a 1/2"X1/2" wire mesh to help hold the insulation up . I would let the 3 sides wide open. opr just put a lattice around the 3 walls.That way you dont have to mess with a crawl space when you think about it this is just like and outside wall only laying down. Have done many add on's this way.
ED
