Insulating basement walls
Old 11-01-04, 08:49 PM
msettip
My basement is warm in the winter because of the boiler and cool in the summer. The bedroom in the basement has paneling up with old insulation behind it.
I wanted to reframe the room with metal studs and use a poly board like one from Owens Corning on the wall and skip the R-13 between the studs.
I noticed some ants crawling from under one wall a couple of months ago. It seems they made a small home in the insulation.
Do I just use adhesive to put the poly board on the basement wall?
Should I still put up a plastic vapor barrier over the studss?
The basement will have a drop ceiling so the walls will be opened at the top.
Thanks,
Matty
Old 11-02-04, 12:47 AM
T
Received 2 Upvotes on 2 Posts
This thread has been split from another regarding vapor retarder on basement walls. Doing so will provide greater opportunities for discussion on this topic.
