Insulation ??
John1's Avatar
03-06-05, 08:13 PM   #1
Insulation ??
What exactly is a "vapor barrier"
Trying to insulate my metal 800 sq ft workshop.
Does the "poly " go on both sides of the insulation or just one side?
Huge Huge moisture problem with my tools here in Louisiana!
Thanks
John1
resercon's Avatar
NJ
03-07-05, 08:16 PM   #2
http://www.eere.energy.gov/consumeri...heets/bd4.html
This site discusses Vapor Barriers. In areas where you experience very humid weather, it recommends the Vapor Barrier goes on the outside on the insulation.
Storkey's Avatar
03-19-05, 05:56 AM   #3
Storkey
Insulation
We just purchased our home and believe it not not there is no entry to the attic so I can check the amount of insulation. Where is the best place to install an entry. Closet / Hallway?
resercon's Avatar
NJ
03-20-05, 04:46 AM   #4
It depends if you want easy access to the attic on a regular basis. If you intend just to gain access to insulate, then in a closet is best. If you want access to not only insulate but to use the attic to store things, then the hallway is best.
