insulate my walls - please
the walls to my house are poured concrete - in the winter the walls can be quite cold - to insulate the walls - can I attach furring strips to the walls, place 3/4" foam sheets between the furring strips, then dry wall. It seems like it will work without losing too much room in the house BUT will it knock the cold down?
with 2 x 4 can it be 2" deep or does it need to be 4" deep - 4" plus drywall would make a fair size room too small, I would think
why should I use pressure treated wood and do I put in a vapor barrier?
oh and by the way thanks - this is a great and helpful site
