Adding Insulation to Attic
TigerDunes's Avatar
SC
03-13-05, 07:57 AM   #1
I need advice on adding insulation to my attic. I have what I believe is commonly called rock wool insulation that has packed down. Several insulation contractors have quoted on adding fiberglass chips to bring insulation up to R-30. Several questions. Is it OK to mix these types of insulation? Also, with the addition, insulation will spill over and cover the 2x4s. This is OK? And finally, I have several places that have plywood down for storage in the attic(in the middle oh house). Both contractors say to just leave this alone. Are there any pitfalls here that I should be aware of and try to avoid? Thanks for your help.
Ed Imeduc's Avatar
MO
03-13-05, 08:20 AM   #2
You might check and put in the foam rafter vents so air can get over the insulation from out in the over hang of the home . Insulation I say mix it all you want . Might look into the celluiose kind. You could blow that in yourself.
ED
